I have an 03 Windstar LX.
My Airbag light is flashing code 16
From my research code 16 is Occupant Classification Sensor (OCS) circuit fault.
This sensor is only on the passenger side correct?
I've disconnected the battery and let the car sit a few minutes to allow the capacitors to bleed down. I jiggled the wires, nothing looks out of place at first glance.
Reconnected the battery and fault code is still present.
What's do I do to determine the faulty connection and or part. What's the fix?
EDIT. I've also found that this has something to do with the green connector. Details are supposed to be listed in the Technical Service Bulletin 03-05-04
Jul 7, 2010 at 9:21 PM
