2002 Ford Windstar Stuttering when accelerating
2002 FORD WINDSTAR
GUYLYDIG
Engine Performance problem
2002 Ford Windstar 6 cyl Front Wheel Drive Automatic
Transmission shifts fine.
Check engine light does not come on.
Vehicle stutters, especially when it goes into high gear and I am accelerating.
It has no power going up hills.
Problem seems to be most pronounced when I shift into high gear, am doing 1500 rpms and accelerating.
I already:
Changed gas filter.
Changed 3 plugs in the front (which were not that bad).
Air intake clean.
Any ideas?
TIA
Guy
Jul 21, 2010 at 2:12 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 21, 2010 at 9:35 PM
TRX2FIVEO
Head over to your local NAPA auto parts and buy this little red tube called Shutter Fixx pull the tranny dipstick and pour it in. problem solved... You torque converter is the issue the thrust bearings are sticking to the plates causing it to shutter when it shifts especially into overdrive. My 02 did it for a long time, I added a tube of this and no problems in over a year so far. Good luck
Jul 27, 2010 at 9:51 PM
