2002 Ford Windstar PASSENGER WINDOW
2002 FORD WINDSTAR
AUNTDEB47
Electrical problem
2002 Ford Windstar 6 cyl
hOW DO YOU REMOVE THE WINDOW MOTOR FROM THE PASSENGER SIDE
Jul 19, 2010 at 6:18 PM
EDWARD.S
  • 166 POSTS
Hi, First Remove The Door panel , Then Remove Plastic Covering , Then Drill Out Rivets For Window Regulator, Remove Bolts Or Rivets From Regulator To Glass, Remove Regulator From Door .Wear Gloves So Your hands Won't get Cut up .The Metal In the Door Is Sharp.
Hope This Helps You,
Good Luck
Edward S.
Jul 19, 2010 at 6:49 PM
