Blower motor not working?
2002 FORD WINDSTAR
106,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID STEELE
the heater doesn't blow and winter is rapidly approaching!
Oct 18, 2009 at 5:33 PM
SQM
  • 6,383 POSTS
There are few reasons for the blower motor to not to come on.
You could have a bad motor, faulty relay, faulty resistor or a wiring issue.
First thing should be checked is the blower motor relay.
Make sure the relay is functional.
Here is how to test the relay:
If the relay is good then the next item to check would be the blower motor.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
I have attached the blower motor replacement instructions for your reference. Also included the fuse block diagram, that shows the relay location.
Thank you.
Aug 1, 2021 at 8:14 PM
