hi
i have this van that has a window problem i think but i dont know for sure , everything was working fine untill the altenator went out
that & the battery got replaced ,the following dinnt work it blew out the driver side headlight,radio & power window on the passenger side quit working .
since then i have replaced the headlight ,all the bad fuses i can find (checked them again to be sure of it ,everything is working now except for the window on the passenger side, along with the power lock which works with a key still.
the window on the passenger side when you hit the button either on the drivers door or the passenger side still does the same ,you can hit them it dont buzz hum click dont make any sound at all.
what else do i need to check?, if it requires taking the door panel off i will need somebody to tell me how to do this,i i have never took a door panel off of anything ,not too sure about how to do this.
any info would be helpful
Jun 6, 2019 at 2:58 PM
(Merged)
