2001 Ford Windstar clutch bearing
2001 FORD WINDSTAR
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
is it possable to replace the clutch bearing w/o removing the compressor ?
Oct 8, 2009 at 8:50 AM
OBXAUTOMEDIC
  • 3,711 POSTS
I take you are replacing the the whole clutch Assembly, would be easier. If you have enough room in front of the compressor to get the remover tool on to remove the clutch assembly then no you won't need to remove the compressor.
Oct 8, 2009 at 9:09 AM
