2001 Ford Windstar ABS HCU modules ??
2001 FORD WINDSTAR
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
MS LEA
the ABS light keeps coming on and the heat in front doesn't work but the heat in the back works fine .What gives is it thermostat problems or what??And can the van still be driven if the ABS/HCU module needs replaced and how much should it cost??
Mar 15, 2010 at 11:40 PM
DAVE H
  • 13,384 POSTS
check the mode control door is working in the heater housing .. have the vehicle plugged into a diagnostic scanner to locate the cause of the ABS fault
Mar 16, 2010 at 7:25 AM
