2000 Ford Windstar Van 3.8L 172,000 miles
2000 FORD WINDSTAR
CNOTE5153
My Windstar recently showed an ABS light. At the same time, the speedometer and odometer quit working. I replaced the Brake Pressure Switch, but it still blows the number 10 fuse. If you keep the BPS disconnected, the speedometer and odometer work. The minute you plug it back in, it blows the 10 Amp fuse again. Do I have a bad ABS wheel sensor? Also, this problem started when we were hit with 10 inches of snow, and the bottom of the vehicle went through some nasty roads.
Feb 19, 2007 at 4:32 PM
KIN CHAN
  • 453 POSTS
there's a brake contrl servo which wire up to the brake pressure switch ....chk tehe wires..u have a short to ground thats why u kept blowing fuses ..its all lite blue and red wires .....good luck man
Feb 21, 2007 at 12:04 PM
NOS
  • 320 POSTS
check out at the wheels and see if all that snow didn't tare a wire loose from a ABS sensor it may be pulled back enough to be shorting to the frame? or even pulled it loose all together. 8) NOS
Feb 21, 2007 at 2:15 PM
