2000 Ford Windstar Periodic hesitation when going into anot
2000 FORD WINDSTAR
150,000 MILES • 6 CYL • FWD • AUTOMATIC
ALLEN MILLS
Periodically my van will hesitate when changing from 1 gear to another. Mostly when I start pressing gas after stopping at a red light
Mar 23, 2010 at 8:43 AM
DAVE H
  • 13,384 POSTS
have the vehicle plugged into a diagnostic computer to check for transmission fault codes .. not all fault's will set the check engine light .. repost with codes for more assistance
Mar 23, 2010 at 3:55 PM
ALLEN MILLS
I had the van put on computer abd these are the codes that seemed to have issues.
PO340-cam sensor A Bank 1 circuit malfunction
PO171-system to lean bank 1
PO174-system to lean bank 2
Thanks,
Allen Mills
Mar 26, 2010 at 2:24 PM
DAVE H
  • 13,384 POSTS
Replace the camshaft position sensor ... Camshaft Position (CMP) Sensor (3.0L)On top rear of engine. Camshaft Position (CMP) Sensor (3.8L)On top right side of engine Also have the vacuum lines/hoses and intake manifold gaskets checked for leaks this is the cause of the P0171/174 codes hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1092.png
Mar 26, 2010 at 4:44 PM
