2000 Ford Windstar obd code for cyl 3 misfiring, egr valve,
2000 FORD WINDSTAR
MJGGJM12
  • 6 POSTS
2000 Ford Windstar 6 cyl 165000 miles
I have a cyl 3 misfire , egr valve, and lean fuel mixture codes. I have canged the egr valve but that did not fix it. I was told by the inspection station that it could be a vaccum leak, and I do here a sucking noise for a second when I rev it up, but the guy said all ford v6's make that quick sucking noise. How can I check for a vaccum leak? I am also going to check the coil when I get home tonight but I am not sure wich cyl is #3.Can anyone elp me I have been trying to figure this out for weeks.
Oct 13, 2009 at 3:33 PM
TONYD1967
have you looked on the pass side of the engine in the back there is a egr sensor that is ran on vacum an one of the lines brake off causing the check engine light to come it should be in the back that were mine is and i have the same car .
Oct 16, 2009 at 8:21 PM
