2000 Ford Windstar Engine Bucking and Popping
2000 FORD WINDSTAR
180,000 MILES • 6 CYL • FWD • AUTOMATIC
AVALONJR
The engine pops and bucks at times. Particularly after coming off a freeway and then accelerating up a ramp. Full horsepower isn't available and a substantial amount of bucking persists unless you go full throttle, which seems to override whatever is causing the problem. This is less of a problem on cool rainy days.
Any idea on how to approach this problem?
Jul 17, 2010 at 10:03 AM
KHLOW2008
  • 41,814 POSTS
Hi avalonjr,
Thank you for the donation.
I would start with the ignition parts. Check spark plugs conditions and ensure they show signs of even combustion. If there are signs of lean conditions, get the fuel pressure tested.
Is the CEL indicating?
Did you try to retrieve for trouble codes?
Jul 18, 2010 at 4:34 AM
