2000 Ford Windstar Electronic Transmission issue
2000 FORD WINDSTAR
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
WINDSTAR92677
After driving for a while transmission disengages. Pull over turn engine off, restart, van drives normal. After few minutes or if speed slows down at traffic light or to make a turn, transmission disengages again. Engine runs fine. After restart engine and transmission run again after slowing down, etc.
Aug 27, 2008 at 12:13 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to go get a transmission specialist to scan and check the electronics, it is a bit hard to make a judgment call with out this information first.
Mark (mhpautos)
Aug 27, 2008 at 12:57 AM
WINDSTAR92677
Will get on the phone and will get a transmission expert to scan the codes.- Basically it sounds like that is not something common and does not ring a bell. Will get those codes. Thank you.
Aug 27, 2008 at 10:21 AM
WINDSTAR92677
They took the pan off an dfound lots of metal, suggesting rebuild. Got ofrfer for $ 2000 with one year warranty. Received $ 3000 form Ford for 3 Years and 100.000 miles, and other shops are offering $ 1600 to $1900 rebuild.
Ebay offeres with otheres used transmissions from $ 600 to $ 1200 incl. shipping. Toi put one of those in the cost are here in California between $ 650 and $800.
Any used transi vendors reputable..?
I would like to go the least expensive route, and trade the car in a.s.a.p., What would you suggest?
Aug 29, 2008 at 6:41 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
That is bad news on the transmission, her in Aust we have seen a lot of these transmission fail, i would only suggest that you see if you can get one from a wrecker or on-line, and and try and do a cash deal with a mechanic to fit it.
Good luck.
Mark (mhpautos)
Aug 29, 2008 at 10:13 PM
