2000 Ford Windstar 2000windstar blend door motor
2000 FORD WINDSTAR
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRISTINA
  • 9 POSTS
Had the van at the mechanic to find the problem. After an hour they said the fuse is fine but there is no power going to the blend door. They said it could be the blend door motor or the blend door itself and that they couldn't go any further that day, could I please bring it back next week.
Is there any way I can check this myself. I know where the motor is and how to get to it I just need to know how to tell if its the motor or the door.
Please help there calling for -26C.
Thank you
Jan 20, 2008 at 9:23 AM
BMRFIXIT
  • 19,053 POSTS
if your engine temp is normal thermostat and all tested ok its a common problem the blend door motor behind right side of dash
https://www.2carpros.com/forum/automotive_pictures/99387_wind_blend_door_1.jpg
Jan 20, 2008 at 9:48 AM
CRISTINA
  • 9 POSTS
Thank you very much for your quick response. Is there any way that you can also tell me where to find the blend door so that I can make sure that it is not broken as well. Since everything else seems to be falling apart with the heater.
Thank You, Thank You, Thank You
Jan 21, 2008 at 9:19 AM
BMRFIXIT
  • 19,053 POSTS
[quote:fe2460ed51="cristina"]Thank you very much for your quick response. Is there any way that you can also tell me where to find the blend door so that I can make sure that it is not broken as well. Since everything else seems to be falling apart with the heater.
Thank You, Thank You, Thank You[/quote:fe2460ed51]
check the wiring diagram up
right side of dash
some have it almost behind the radio and ashtray
it has a square plug wires
Jan 21, 2008 at 5:01 PM
CRISTINA
  • 9 POSTS
The ford mechanic got back in there today and says it's not the actuator. The blend door is broken. Apperantly the part of the actuator that sticks out and goes into a hole in the pendulum is the problem. Something (can't remember name) inside that hole is what is broken. They say they need to remove to whole dash to get to it. How hard is it to do this myself because they're quoting 600 for labor and 600 for the part?
Jan 21, 2008 at 6:03 PM
BMRFIXIT
  • 19,053 POSTS
[quote:6734a3226a="cristina"]The ford mechanic got back in there today and says it's not the actuator. The blend door is broken. Apperantly the part of the actuator that sticks out and goes into a hole in the pendulum is the problem. Something (can't remember name) inside that hole is what is broken. They say they need to remove to whole dash to get to it. How hard is it to do this myself because they're quoting 600 for labor and 600 for the part?[/quote:6734a3226a]
Bit high for me get another quote
get another opinion too
Jan 21, 2008 at 6:15 PM
CRISTINA
  • 9 POSTS
I'm in a small town in Ontario. My regular mechanic won't go anywhere near this problem because he says the last time he tried to fix this problem on a ford it took him 16hours. At least he's honest, but I'm not sure where else to look, part stores keep telling me I need to get this part directly from ford and there labour is $84/hour. Do you have any suggestion?
Jan 21, 2008 at 6:23 PM
BMRFIXIT
  • 19,053 POSTS
[quote:04a9c12dc5="cristina"]I'm in a small town in Ontario. My regular mechanic won't go anywhere near this problem because he says the last time he tried to fix this problem on a ford it took him 16hours. At least he's honest, but I'm not sure where else to look, part stores keep telling me I need to get this part directly from ford and there labour is $84/hour. Do you have any suggestion?[/quote:04a9c12dc5]
ask him if he can move the door for u
so you can get heat for know
get a phone book call around
i can see his point not a job i like to do my self
Jan 21, 2008 at 6:56 PM
CRISTINA
  • 9 POSTS
They were going to try that but they said the way it was broken it wouldn't work. They said the door was broken inwards and that they couldn't prop it shut. Do you think they'r scamming me.
Jan 22, 2008 at 7:15 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d6b368489d="cristina"]They were going to try that but they said the way it was broken it wouldn't work. They said the door was broken inwards and that they couldn't prop it shut. Do you think they'r scamming me.[/quote:d6b368489d]
try to get a different opinion
if they want to help they could
are you sure the door is stuck and its not the motor thats no good !!!!
if door get stuck it will strip the gears in the actuator
Jan 22, 2008 at 5:33 PM
04BOLT
  • 7 POSTS
look up blend door motor and nail fix. you can put a nail through the end of it to get it to grab and open and close the door. I thought I had the same problem, but it was just the blend door motor. There are several how to's with picures out there.
Jan 24, 2008 at 8:52 PM
CRISTINA
  • 9 POSTS
Finally able to get a picture of my blend door to show you. I was comparing it to some of the fixes shown for the nail fix but mine doesn't look the same.
https://www.2carpros.com/forum/automotive_pictures/109797_P1040782_1.jpg
Jan 27, 2008 at 8:37 AM
BMRFIXIT
  • 19,053 POSTS
check your PM
i answered you PM
Jan 27, 2008 at 11:44 AM
