1999 Ford Windstar rack n pinion
1999 FORD WINDSTAR
LILBALLER
Engine Mechanical problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic
I did a rack and pinion job on this 1999 ford windstar. the only thing i unplug was the o2 sensor. i didnt unplug anything else. after finishing the job the car is throwing all these transmission codes. the car doesnt even want to shft gears anymore. i have no idea what would cause that. the O/D light is flashing too. The check engine light doesnt come on but my code reader is showing up 11 ccodes..any idea?? All the plugs to the tranny is pluged in i didnt touch none of it
Apr 16, 2010 at 9:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like water / fluid may have gone into the PCM . check PCM cover to see if it's loose or if any water damage is noticable around PCM connector.
Apr 16, 2010 at 9:10 PM
LILBALLER
Nope I did almost everything check every plug
Apr 16, 2010 at 9:50 PM
