1999 Ford Windstar pulling a transmission out
1999 FORD WINDSTAR
1NONLYNIKKI
Transmission problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic
how can i get a transmission out?...i have disconnected all wires, removed all bolts, removed both c v axles motor mount bolts...what else needs to be done in order to get the transmission to drop or am i going to have to pull the whole motor out in order to get the transmission out?
Apr 10, 2010 at 12:59 PM
2CARPRO JACK
  • 11,533 POSTS
On those FWD vehicles you need a special rig to hang the engine from (Goes across strut towers) so that you can remove the front cradle (frame).This is how you get enough clearance to remove the trans. The engine stay in the vehicle and hangs from the rig.
Apr 10, 2010 at 3:08 PM
