1999 Ford Windstar p1131 code
1999 FORD WINDSTAR
NEOLITIC
Computer problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic 75k+ miles 3.8L V6
Is this amass air sensor code?
I can't find a photo that looks like my car's set up.
Is the MAF the part between the throttle body and
the intake manifold?
What do I use to clean it, throttle body cleaner,
contact cleaner, or must it be the CRC MAF cleaner?
Oct 31, 2008 at 1:52 PM
DTC P1131 indicates the system is correcting RICH for an overly LEAN condition. The Heated Oxygen Sensor (HO2S) voltage is less than 0.45 volts. This is usually due to a vacuum leak after the MAF. It can also be caused by a bad PCV valve or PCV system hose
Oct 31, 2008 at 4:17 PM
NEOLITIC
[quote:50911b54e5="rasmataz"]DTC P1131 indicates the system is correcting RICH for an overly LEAN condition. The Heated Oxygen Sensor (HO2S) voltage is less than 0.45 volts. This is usually due to a vacuum leak after the MAF. It can also be caused by a bad PCV valve or PCV system hose[/quote:50911b54e5]
Thanks, guy at the parts store told me that the 1131 code was air mass, and P0135 was #1 bank O2 sensor.
Oct 31, 2008 at 6:38 PM
Clean the MAF with a spray tuner cleaner, #64-4315 available at radioshack
Nov 1, 2008 at 2:14 PM
