1999 Ford Windstar no power
1999 FORD WINDSTAR
MARYANNRICKY
Transmission problem
1999 Ford Windstar 6 cyl Front Wheel Drive Automatic
the engine runs good but when i put the transmission in gear (drive/reverse) it wont move the first time it happened i put it on reverse and nothing the i pushed the gas more and it moved slowly in reverse when i went forward i had to accelerate a lot for it to move since then it wont move foreword or reverse what could the problem be thanks
Mar 9, 2009 at 4:26 PM
Make sure the fluid is full. also, make sure the linkage to the trans is attached. If these are ok, chances are you will need to have it checked by a transmission tech. It may have internal damage.
Mar 11, 2009 at 10:35 PM
