1999 Ford Windstar Heater controls
1999 FORD WINDSTAR
103,000 MILES • 6 CYL • FWD • AUTOMATIC
JIM TANASSE
heater temp control makes a steady rithimic clicking sound as it is moved to warmer position. the clicking frequency increases the further right (warmer) you move the control. I need to access the control motor and other parts behind the dash but I don't know how to remove the dash area without damageing it.
Jan 16, 2009 at 12:05 PM
IMPALASS
  • 3,112 POSTS
Hello - I think this is what you are asking for. Control Components Notes REMOVAL Disconnect the battery. CAUTION: The slider knobs are illuminated using a LEDs. Use care not to damage them when removing the slider knobs.
https://www.2carpros.com/forum/automotive_pictures/248015_1_55.gif
Remove the ash receptacle. Remove the audio unit.
https://www.2carpros.com/forum/automotive_pictures/248015_2_67.gif
Remove the screws.
https://www.2carpros.com/forum/automotive_pictures/248015_3_46.gif
Unsnap the panel.
https://www.2carpros.com/forum/automotive_pictures/248015_4_35.gif
Disconnect the connectors.
https://www.2carpros.com/forum/automotive_pictures/248015_5_24.gif
Remove the control assembly. Remove the screws. INSTALLATION To install, reverse the removal procedure. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Jan 16, 2009 at 12:49 PM
IMPALASS
  • 3,112 POSTS
Hello –
Hey also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you. I would check these out also……
00B51
09/01/2000
Campaign - AX4S Rear Lube Tube Replacement
99B14
07/01/1999
Campaign - Armrest Discrepancy Compensation
99B11
06/01/1999
Campaign - Components Upgrade
99B10
06/01/1999
Campaign - Overhead Console Bracket Replacement
01S26
09/01/2001
Recall - Rear A/C Blower Wiring
NHTSA01V262000
08/10/2001
Recall 01V262000: Heater Blower Motor Circuit Protection
NHTSA01V261000
08/08/2001
Recall 01V261000: Windshield Wiper Defect
NHTSA00V351000
10/30/2000
Recall 00V351000: Accessory Delay System Non-Compliance
NHTSA99V147000
06/07/2000
Recall 99V147000: Brake Master Cylinder Labels
NHTSA99I001000
06/02/1999
Recall 99I001000: Overhead Concole Retaining Bracket
99S17
06/01/1999
Recall - Brake Fluid Warning Label Installation
Jan 16, 2009 at 6:59 PM
