1998 Ford Windstar OBD Code P0340
1998 FORD WINDSTAR
13,375 MILES • 6 CYL • 2WD • AUTOMATIC
FRUSTRATEDFORDOWNER
I have a 98 Ford Windstar 3.8. It failed emission test with the code P0340. The camshaft position sensor was replaced still showed code distributor shaft (syncronizer) replaced wires checked, cam shaft checked both ok. Still showing code P0340. What do I do now?
Jun 14, 2010 at 9:51 PM
DOCFIXIT
  • 18,828 POSTS
Code can be set by AC signal interference from alternator. Erase code disconnect ALT run if code does not reset then replace ALT.
Jun 15, 2010 at 3:16 PM
