I have a 98 windstar GL. The front and rear wipers have stopped working. If you press the front washer switch, the front wipers do the customary 3 wipes and then park back in the off position. I have checked all the fuses and relays and they are in working order. The washer switches work on both front and back. The diagrams I have show that the wiper motor circuits go thru the GEM module. The washer pump motors do not go through the GEM module. The door ajar lights, window switches and a few other circuits also go through the GEM module also. Everything but the wipers work. Is it possible that the "wiper" portion of the GEM is bad? Also is the GEM located under the steering column next to the center console that houses the radio? Does anyone have a picture of a GEM module?
Thank you
Thank you
Sep 12, 2009 at 12:13 PM
