with all doors shut the icon says that a door is open. how do i find out which door is causing the problem?
Feb 25, 2008 at 10:04 AM
MASTERTECHTIM
CERTIFIED EXPERT
first try spraying wd40 on all door latches and work them by opening and closing door very quickly, this usually frees up the door switch. if not you will need to scan the bcm or disconnect each door one at a time
