Where is the daytime running light module located on this model?
Mar 11, 2008 at 11:11 AM
2CARPRO JACK
CERTIFIED EXPERT
L/F of engine compartment, between battey and core support
Mar 11, 2008 at 3:07 PM
ANDYC
MEMBER
Thanks for the info. But what is the core support?
Mar 11, 2008 at 3:11 PM
2CARPRO JACK
CERTIFIED EXPERT
The body that runs across the front of the van that the fenders attach to and the radiator mounts to
Mar 11, 2008 at 5:40 PM
ANDYC
MEMBER
so I found the control module replaced it and still have the same problem. The lights stay on even when you shut the car off. I have tried the relay, disconnected the switch inside the van. I don't know where else to look. Any help would be great. Thanks
Mar 11, 2008 at 7:38 PM
2CARPRO JACK
CERTIFIED EXPERT
Is that a reg Windstar? GL? LX? Limited? want to be sure to get the right diagram
Mar 12, 2008 at 7:44 AM
ANDYC
MEMBER
It is a LX model. Built in Canada
Mar 12, 2008 at 10:07 AM
2CARPRO JACK
CERTIFIED EXPERT
Try unhooking the dimmer (hi-low beam) switch
Mar 13, 2008 at 2:31 PM
ANDYC
MEMBER
I disconnected the module all together. It seems to have fixed my problem. Thanks for all the help
