1998 Ford Windstar coolant in oil
1998 FORD WINDSTAR
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIZZYB
When the problem happened I noticed I was not getting hot air from my heater. I removed the radiator cap a saw a brown foam at the rim. I checked the oil dip stick and it was a bit high and seemed watery. I am not seeing any smoke from the exhaust. I think it is a head gasket problem. I let the van sit for a few weeks. I was going to drain the coolant and oil and try something like Bar's head gasket fix. When I started to drain the coolant I saw that it was green and clear without a hint of oil so I stopped draining it. I started the van and let it run until it was at normal operating temp. The heater was now working fine. I checked the oil again and there is definately water in there. Bottom line, should I try the gasket fix?
Jul 26, 2009 at 3:04 PM
DOCFIXIT
  • 18,828 POSTS
If there is coolant in oil it will look like a chocolate malt does yours? Oil could be thin by gasoline in oil.
Jul 26, 2009 at 3:22 PM
BIZZYB
Thanks for the response. How can I check if it is gas in the oil?
Jul 26, 2009 at 3:40 PM
DOCFIXIT
  • 18,828 POSTS
Hold lighter to oil on stick if it lights gas in oil
Jul 26, 2009 at 3:50 PM
