1997 Ford Windstar rough running engine
1997 FORD WINDSTAR
37,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKESMOOV1
97 ford windstar with 37k running rough. Running rough from start and when accelerater is pressed. Overdrive light is blinking. stalls when put in gear.
Jun 16, 2010 at 9:30 PM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
12.Manifold absolute sensor.
Jun 18, 2010 at 6:45 AM
