1996 Ford Windstar Your answer to both banks lean
1996 FORD WINDSTAR
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEZGIGI
As I explained all feeds check out. Both on running and not running tests values are proper. Can you give me any other advise? Please respond to my email address ([email protected]) As your system would not recognize me I had to enter another email to get the question in,([email protected])
Thank You Don Cole [email protected]
Sep 8, 2010 at 5:39 PM
WRENCHTECH
  • 20,761 POSTS
Sorry, but we do not respond directly through e-mail.
You question is not real clear and you didn't post code numbers as you should have but i expect you have PO171 and PO174. This is a common combination on Fords and is usually caused by a severe vacuum leak. They are notorious for sucking holes through the rubber connectors for the large vacuum supplies like the PCV and brake booster. Listen for a hissing noise when idling and try to follow it to it's source.
Sep 8, 2010 at 6:03 PM
