1996 Ford Windstar engine will not crank
1996 FORD WINDSTAR
140,000 MILES • 6 CYL • FWD • AUTOMATIC
MORIARTY34
My ford windstar will not crank, i just replaced the starter and solenoid and it started right up an hour later i tried to start it again it would not start.I had the battery checked and it is good.All of my lights and engine gauges come on when i try to start but it will not turn over,any ideas?
Feb 19, 2010 at 12:35 PM
Pick your symptoms:
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good.
Feb 19, 2010 at 1:18 PM
LAMBINO
Hi I also have this problem, van was running fine until I went to get some gas and afterwards van wouldn't start. I could here the starter relay clicking when trying to start the van and I never had starter issues. What else can I look for to check a cause of what is making the van not crank?
Oct 28, 2014 at 7:19 AM
