1996 Ford Windstar Air comes out defrost, no matter what se
1996 FORD WINDSTAR
12,500 MILES • 6 CYL • FWD • AUTOMATIC
GREASY3
MEMBER
1 POST
FOLLOW
air comes out defrost no matter what the switch is set on..... Also no dash lites good fuse..
Jun 29, 2010 at 9:57 AM
CERTIFIED EXPERT
You are looking for a vacuum leak with this problem. The air flow direction is changed by vent doors. They are actuated by vacuum.
Check under the dash for vacuum leaks as well as under the hood. If you are lucky, with the engine running, you may hear a hissing noise from the leak. Check that and let me know what you find.
