I have a 1995 Ford Windstar that the tachometer is moving even though the van is not running. The van stalled, cranked but would start, and had to be towed. We replaced the crankshaft position sensor and the van started up and ran for about 3 weeks. Then the same thing happened, we had to have it towed, once again turns over but will not start, and replaced the camshaft position sensor. The van started up and sometimes starts, sometimes doesn't and when it doesn't, the tachometer is moving. Also, when the van will not start, when the key is on, the cooling fan will also come on. When the tachometer is not moving with the key on, the cooling fan does not come on.
Aug 28, 2009 at 8:55 AM
