1995 Ford Windstar runs hot and poor heat
1995 FORD WINDSTAR
150,000 MILES • 6 CYL • FWD • AUTOMATIC
69BISCAYNE
Van has 3.8 ford replacement engine 7 years old and 60000 miles on it.About 6 months ago it was running hot,replaced t-stat,was ok until 2 weeks ago temp. gauge was irratic and then going into red and poor heat.Replaced t-stat with Stant.It was ok and great heat for about 2 weeks,now back to red zone in 5-10 miles and poor heat.Runs ok,has no missfire and no check engine light.Any ideas?I am going to try running it without t-stat and see what happens.Any thoughts would be greatly appreciated.
Feb 17, 2010 at 7:36 AM
If the radiator and water pump are okay -could be air in the system try bleeding it and see what happens if it continues get it block and pressure tested. Test the thermostat
Feb 17, 2010 at 7:41 AM
69BISCAYNE
[quote:b19d2aaf25="69biscayne"]Engine Cooling problem
1995 Ford Windstar 6 cyl Front Wheel Drive Automatic 150000 miles
Van has 3.8 ford replacement engine 7 years old and 60000 miles on it.About 6 months ago it was running hot,replaced t-stat,was ok until 2 weeks ago temp. gauge was irratic and then going into red and poor heat.Replaced t-stat with Stant.It was ok and great heat for about 2 weeks,now back to red zone in 5-10 miles and poor Report Spam ok,has no missfire and no check engine light.Any ideas?I am going to try running it without t-stat and see what happens.Any thoughts would be greatly appreciated.[/quote:b19d2aaf25]
Feb 17, 2010 at 12:08 PM
