I removed the mode-door motor, cam plate and cam, to lube the cam. When I put it back together, I don’t think i had the cam in the correct position and powered the climate control. When the motor wouldn’t turn, i took it apart again and energized the motor. You’ll notice in the TCB it says to "Do Not Energize the Mode Door Motor Without It Being Connected". So, that is what I accidentally did and now the gear from the motor will not fit into the cam. How can I fix this?
Jan 9, 2023 at 7:00 AM
