Air Conditioning problem
2005 Ford Truck 6 cyl Two Wheel Drive Automatic
turned on a/c a few weeks back and no cold air would come out at all. Plenty of air, but not cold.
took the motorhome to a rv repair shop and they said:
Cause: low on freon , add 1 lb. started to cool to 44 degrees. As it warmed up A/C temp dropped. Correction: Diag. Compressor and dryer are needed.
I brought motorhome back home and a/c put out constant 51 degree air for over an hour (74 degree outside temperature).
Do you feel the compressor is bad?
Mar 18, 2009 at 8:00 AM
