Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Truck
Engine
Camshaft
Camshaft Sensor
Location
2005 Ford Truck cam position sensor location
2005 FORD TRUCK
136,061 MILES • V8 • 2WD • AUTOMATIC
BUDDYG3205
MEMBER
FOLLOW
where is the cam position sensor located on F550 with 6.0 L
May 12, 2009 at 11:17 AM
DOCFIXIT
CERTIFIED EXPERT
Hi
Located left cylinder headjust below valve cover
Thanks for donate
May 12, 2009 at 11:55 AM
JDL
CERTIFIED EXPERT
driver-side, downlow, toward the front of engine. You could also check the wiring colors at the connector, compare to wiring diagram, to make sure.
