pcv location
2004 FORD TRUCK
BKRAEMER
  • 4 POSTS
Engine Mechanical problem 6 cyl Two Wheel Drive Automatic 85000 miles
On my 2004 Ford ranger. I would like to know the location of the pcv valve on the 3.0 liter v6 engine. I can tell you, its not on either valve cover.
Dec 19, 2009 at 7:37 PM
Hi bkraemer, Welcome to 2carpros and selecting us as your auto repair site Feel free to ask questions at anytime and Merry Christmas and a Happy New Year 2010 POSITIVE CRANKCASE VENTILATION (PCV) VALVE REMOVAL
https://www.2carpros.com/forum/automotive_pictures/12900_pcv1_1.gif
Disconnect the positive crankcase ventilation (PCV) valve. Disconnect the PCV valve electrical connector. Disconnect the PCV valve tube from the PCV valve.
https://www.2carpros.com/forum/automotive_pictures/12900_pcv2_1.gif
NOTE: A new PCV valve must be installed if removed from the cam cover. Rotate to release and remove the PCV valve. INSTALLATION To install, reverse the removal procedure.
Dec 19, 2009 at 8:16 PM
BKRAEMER
  • 4 POSTS
I ask were is it located. It is not on either of the valve covers. The book I have says its on the cam cover. Is the cam cover on top of the engine between the valve covers? Is the valve toward the front of the engine or is it further back?
Dec 19, 2009 at 10:25 PM
2004 Ford Truck 6 cyl Two Wheel Drive Automatic 85000 miles I had to go in circles to find the answer for you in my Alldata and Mit1 .com auto references. See below: The PCV valve is on top rear of engine see below
https://www.2carpros.com/forum/automotive_pictures/12900_pcv3_1.jpg
Dec 20, 2009 at 12:22 AM
BKRAEMER
  • 4 POSTS
Thank you again for your help. I have put your web site in my favorites list. You can be sure if I have any more car/truck repair questions. I will be back. Thank you again. Have a merry Christmas and happy new year.
Dec 20, 2009 at 12:38 AM
