1999 Ford Truck fuel leakage
1999 FORD TRUCK
ROGERLRICEJR
Engine Mechanical problem
1999 Ford Truck V8 Four Wheel Drive Automatic
1 have a 1999 f250 4x4 with a 7.3 desiel engine. The problem is with the fuel system. the by pass or return (?) is spewing more fuel than i can put in. I've trierd to cap it, but that doesn't work. it just started. I've heard that i can fix it by putting in a new bolt(?) with o rings. can you tell me what needs to be done to fix this problem. Thank you for your time.
Roger Rice
Nov 28, 2008 at 10:37 AM
Roger, Where is the line leaking from? Is it the sending unit at the fuel tank? If so, remove the tank and replacing the sending unit.
Dec 12, 2008 at 1:40 PM
