1999 Ford Truck Dead battery
1999 FORD TRUCK
16,200 MILES • 4 CYL • AWD • AUTOMATIC
AHMORNING
I have a 99 F-150, we have replaced alternator and battery. The battery is still draining quickly. Have taken to repair shop and were told it was a bad alternator. We took the alternator back to parts store where they tested it and said it was fine. Does anyone have any ideas as to why the battery is still draining? Please help...(can't afford another trip to repair shop, alternator and battery cut into our funds)
Aug 22, 2009 at 2:10 PM
There's probably a short somewhere in the electrical system that's draining the battery. Battery drain test:
https://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_124.jpg
Aug 22, 2009 at 2:13 PM
JDL
  • 16,098 POSTS
Hello, did the store check the alternator on or off the vehicle? If it was off, it is possible the alternator is good, maybe a problem with the alternator wiring circuit? With everything turned off, it is possible you have a battery drain? I don't have the specs in front of me, for the allowable drain, usually well less than 1/2 amp.
Aug 22, 2009 at 2:18 PM
AHMORNING
They did check the alternator when it was off. Also, they have checked for a battery drain. I was thinking the wiring between the alternator and battery, but I'm not really sure.
Aug 22, 2009 at 2:37 PM
JDL
  • 16,098 POSTS
If you have a digital multimeter, you can check the charging system. With everything turned off, take a reading across the battery posts. The generic figure for a fully charged battery is around 12.6 volts. Then start the vehicle, take a second reading across the battery posts, the second reading should be higher than the first, if it isn't, take a reading at the bat terminal of the alternator, see how it compares to the battery reading.
Aug 22, 2009 at 3:02 PM
