Engine Performance problem
1999 Ford Truck V8 Two Wheel Drive Automatic
When you push gas pedal down past, it will go, but it cuts out. when you let up to stops cutting out. If you slowly put on the gas, it will not cut out.
I have changed the fuel filter, fuel pump, spark plugs, new spark plug wires. Even put it on a computer and it didn't show any problems.
May 6, 2009 at 3:40 PM
