1998 Ford Truck High idle and reving
1998 FORD TRUCK
98,000 MILES • 6 CYL • 4WD • MANUAL
HAZY
I have a 1998 Ford Ranger XLT 4x4 with a 3.0L eng. and a 5 speed manual trans. Sometimes it will rev up to 2500 to 3000 RPM when I push in the cluth pedal. I have installed IAC valve, new EGR valve and it only helped for a short time. will I have to install a new PCM. Please help me
[email protected]
Sep 4, 2010 at 8:40 AM
BILLYMAC
  • 2,204 POSTS
no prob not go to ford get it reflashed
Sep 13, 2010 at 5:54 PM
MIKE H R
  • 3,094 POSTS
At times I have seen many vehicles do the same thing , sometimes there is a small buildup of carbon in the throttle body that makes it stick. try cleaning out the air intake to the throttle body with throttle body cleaner.
Sep 18, 2010 at 10:19 AM
HAZY
I iinstalled a tp sensor and that took care of the problem.
Thank you
[email protected]
Sep 18, 2010 at 7:59 PM
MIKE H R
  • 3,094 POSTS
Had a high idle on my wifes 2005 f150, used throttle body cleaner and cleared it up. Only had one tp sensor hang up and that was on a firebird. I am glad you got the problem fixed. Mike
Sep 23, 2010 at 9:56 AM
