Electrical problem
1997 Ford Truck V8 Two Wheel Drive Automatic 150.00 miles
my turn signals do not work . They worked for a while, but then quit. Checked fuse, new switch,new flasher ,new relay,checked bulbs. Coul the wires be loose in the harness? I noticed when i changed the switch a wire was loose the plastic piece inside the harnes was broken . So i tried to rig it ,could other wires be loose also?
Nov 16, 2008 at 5:14 AM
