1997 Ford Truck idles rough
1997 FORD TRUCK
203,000 MILES • V8 • 4WD • AUTOMATIC
GMAN250
replaced plugs wires coils fuel filter
Feb 11, 2010 at 6:33 PM
Rough/Misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Feb 11, 2010 at 7:14 PM
