1996 Ford Truck Possible Fuel in injectors?
1996 FORD TRUCK
MELMACK
  • 5 POSTS
Engine Mechanical problem
1996 Ford Truck Two Wheel Drive Manual
My 96 PowerStroke 7.3 started sputtering today like there was water in the fuel. It idled fine but as soon as I hit the gas in gear it would sputter and sometimes quit and need a restart. Oil level is good, new fuel filter.(It did this a two weeks ago, killed a fairly new fuel filter) So I forced it 1/2 mile slowly to the parts store. I topped the oil off, added Iso heet to both tanks, it continued to cut out for a minute then died. Now it just turns over like it did 6 months ago when the oil filter came loose and It had no oil pressure to fire the injectors. It won't try to fire at all. It has plenty of oil this time. Did I get too much water in my injectors? If so, how do I purge the injectors/clean everything out?
Feb 23, 2010 at 1:15 PM
MERLIN2021
  • 17,250 POSTS
I emailed you a copy of testing fuel pressure, it could be a weak fuel pump setup. There is also a Technical service bulliten on several parts, glow plug relay, a short in the injector cicuits or IDM, Press Ctrl+F to find exact text
7.3L D.I. TURBO - REDUCED POWER - NO START - NO DTC
TECHNICAL SERVICE BULLETIN
Reference Number(s): 03-21-3, Date of Issue:  October 6, 2003 FORD:1994-1997 F SUPER DUTY, F-250, F-350; 1997 ECONOLINE Superceded Bulletin(s): 95-6-13, Date of Issue:  March 27, 1995 Related Ref Number(s): 03-21-3, 95-6-13
Article 95-6-13 is being republished in its entirety as part of a consolidated 7.3L diagnostic aid booklet.
DRIVEABILITY - REDUCED POWER - NO START - 7.3L D.I. TURBO - IDM MODULE - NO DIAGNOSTIC TROUBLE CODES
A "no-start" or "reduced power" condition may occur intermittently on some vehicles. This may be caused by a short in the injector circuits or the IDM module.
Follow the diagnostics listed in the Diagnostic Guide and refer to the following Service Procedure.
http://www.ondemand5.com/mric/common/asp/Article.aspx?MOD=TSBART&YEAR=19...
Part Name IDM Module
Page 1 of 2
1.If, after completion of all the steps in the Power Stroke 7.3L (DI Turbo) Diesel Diagnostic Guide, you are unable to pinpoint the cause of the concern, proceed with the following steps. 2.Disconnect the IDM Module connector and using a DVOM, measure the resistance between the injector circuits to ground. If it is less than 5 ohms resistance, repair the short in the circuit and retest. 3.If the concern still exists, replace the IDM module.
There is also one for the injector cusion seals. this can cause all kinds of problems and is only detected by removing and inspecting them. A new design seal kit is available. If any one needs replacing, all must be changed.
Feb 25, 2010 at 7:17 PM
MELMACK
  • 5 POSTS
I will look into the pressure once I can get my hands on a tester. BTW, it started running today after cranking it with ether(I know its bad for the truck, I just used a little and no glow plugs). It idled for an hour then died when I tried to drive it. I got it running again later. Now it seems to drive fine but it lopes at a light. There is a component on the fuel bowl that is dripping fuel slowly now. The parts guys cannot identify it. It looks like a oil pressure sensor and has a red wire with a stripe on it. The wire connects like a tiny spark plug. It's right next to the shrader valve mentioned in the testing procedure. What is this?
Feb 25, 2010 at 9:16 PM
MERLIN2021
  • 17,250 POSTS
Can you post your reply to my email here? I need to know exactly what colors the wire is, is it red with a green stripe?
Feb 26, 2010 at 4:01 PM
MELMACK
  • 5 POSTS
No problem.. I'm new to this forum sry. The wire is red with yellow stripe. The red with green stripe comes off the solenoid switch. This wire goes to the ? device on the drivers side.
https://www.2carpros.com/forum/automotive_pictures/488576_DSCF1039_1.jpg
Feb 27, 2010 at 9:36 AM
MERLIN2021
  • 17,250 POSTS
Looks like the sender for the wait to start light on the dash.
I will need the series of your truck as well, 150? 250? 350? Super duty?
Feb 28, 2010 at 7:11 AM
MELMACK
  • 5 POSTS
OK, it's an f-350. But this device is right on the side of the filter bowl. It has fuel flowing through it. As I said earlier, it's leaking fuel out the side. How could this have anything to do with the glow plug circuit? I seems like some sort of pressure switch, regulator, cutoff ect.
Feb 28, 2010 at 9:19 AM
MERLIN2021
  • 17,250 POSTS
It's a typical sending unit(pressure sensor type) turns on warning lamps. If it leaks, replace it.
Feb 28, 2010 at 10:13 AM
MELMACK
  • 5 POSTS
Thank you. So this leaking will not effect the non starting situation? I managed to get it running for a few miles and noticed this sensor was leaking. It drove around a few miles with only one stutter. I started it the next morning and it idoled fine for several minutes. Then, I pulled out of the driveway and it died. It would not start with or without either. It sputtered a little with a quick burst of ether but nothing else. I drained the fuel bowl into a cup and found no water. The fuel smells funny though. The last fuel I got was extremely clear and odorless. I'm starting to think something is wrong with my fuel.
Feb 28, 2010 at 3:58 PM
MERLIN2021
  • 17,250 POSTS
They have test strips at the parts store that detect water, but your oil is important too, if it's low, dirty or foaming, truck will have problems starting.
Feb 28, 2010 at 4:05 PM
