1994 Ford Truck No cab heat
1994 FORD TRUCK
120,000 MILES • V8 • 4WD • AUTOMATIC
JR1TRAINER
Ther is no heat coming from the core. The thermostate appears to open up as I can feel the movement of hot water through the upper hose as it opens. There is no movement of water through the heater hoses. Lost at this point
Nov 23, 2008 at 6:59 PM
One of the heater hose coming from the engine should be feeding the heater core do you have this?
Nov 23, 2008 at 7:12 PM
JR1TRAINER
[quote:fe76a6d597="rasmataz"]One of the heater hose coming from the engine should be feeding the heater core do you have this?[/quote:fe76a6d597]
Yes the feed and return are in place and there is some heat as far as the end of the metal tube leaving the engine. There is no hot coolant feeding up the heater hose?
Nov 23, 2008 at 7:25 PM
Disconnect both heater hoses from the heater core -fill the radiator and crank engine over-is coolant coming out of the heater hoses?
Nov 23, 2008 at 7:37 PM
