i currently have a problem with the gear shift selector. i can not get it out of park. i have checked the steering column and there appears to be no solenoids of any sort. also looked at the brake pedal nothing there. however the problem started a day or two after some one adjusted the steering column ignition switch for the owner. the owner states that when she tried to start the truck she heard a noise or snap sound in the steering column. my question being is there some sort of a mechanical lock in the steering column that locks the gear shift. i have it apart at this time and can see the steering wheel lock which seems to be working properly. do i need to continue further into the steering column?
May 31, 2009 at 9:04 PM
