Electrical problem
1990 Ford Truck V8 Four Wheel Drive Manual
will pcm cause a no spark no fuel pump .the fuel pump was running with switch off changed fuel pump now will not run changed fuel pump now pump does run and no spark pull plug wire and grounded it and cranked motor no spark coil checked fine getting voltage and continuity
May 3, 2009 at 12:07 PM
