1972 Ford Torino starter
1972 FORD TORINO
GREATDANE
Transmission problem
1972 Ford Torino V8 Two Wheel Drive Automatic
I put lincoln 89 302 in it it had a truck trans. it the car when got it the starter want engae what do i need to do to make it work. Thanks
Jan 8, 2009 at 9:13 PM
HMAC300
  • 48,601 POSTS
if you have the transmission pan on it, manually check to see i the starter gear even hits the flywhell. Make sure to do this with the attery disconnected. You may have the wrong flywheel in it or the teeth are worn off and you need to replace the teeth on the flywheel.
Dec 17, 2009 at 7:20 PM
