Engine Cooling problem
1970 Ford Torino V8 Two Wheel Drive Automatic
OK i have a 87ish 302 bored and stroked 331in a 70 torino, I'm treating it like a 87ish mustang 302 as for parts. My bracketing for my ac compressor snapped. It wasn't connected anyways so i took it out completely, then i ran into a water pump issue due to the fact that one less pulley was on my system so the water pump would rotate in the wrong direction, so i decided to get an electric water pump and now I'm running into leaking problems with it and cant get it to work due to the fact that the water pump only runs for a few seconds then stops the fuse is fine and the company "Proform" said it must be a short. Anyways. my questions are should i get a reverse mechanical water pump and where can i get one, and where can i get a pulley for it with a 6 rib serpentine groves on it
Jun 25, 2010 at 7:56 PM
