Thermostat Install
FORD THUNDERBIRD
TAZZY5307
I have a 1990 T-Bird, 3.8 Engine, with about 120K miles on it. This car has a small leak from the Thermostat Housing (bottom section).
I've replaced the housing and the thermostat and no luck - the dripping still ocurs!
Is there a special way the thermostat needs to be installed?
I'm going crazy here!
Tony
Sep 5, 2007 at 10:15 PM
[quote:176138bdb7="Tazzy5307"]I have a 1990 T-Bird, 3.8 Engine, with about 120K miles on it. This car has a small leak from the Thermostat Housing (bottom section).
Tony[/quote:176138bdb7]
If it has a jiggle valve on it and normally it has an indentation within the housing to install it correctly.-could be a miniature crack on the manifold.
Sep 6, 2007 at 12:16 AM
