My 1995 Ford Thunderbird LX brakes very hard. Light pressure on the brake pedal causes the car to stop quickly. there is no pull, vibration, noise, or other typical problems. If you press frimly the brakes stop you...quickly. With 139,400 miles I'm sure the brakes have been dealt with prior to my purchase. The issue, however, is hard braking. My new driver (daughter) finds it tough to adjust to the hard braking. Is this a problem that is easily fixed in the driveway? When the pedal is pressed it moves towards the floor. the next depress of the pedal moves it to the floor but not as far as the first. the master cylinder is full. I'm trying to get her a safe car to drive. Thanks
Jan 17, 2007 at 8:33 PM
