97 TBird Front End Noise
1997 FORD THUNDERBIRD
JASONHARJO
97 Ford Thunderbird, 132K miles, 4.6L V8
I have a rattle sound coming from the front suspension of my car. I took it to a local mechanic. He told me I needed to replace my rack and pinion. Is it common for the rack and pinion to wear like this? I do many repairs on my car and I was wondering how hard it is to replace the rack and pinion and the lower ball joints?
Jul 31, 2007 at 11:54 AM
JASONHARJO
I apologize for the limited info. Thanks for the quick response. The rattle noise happens at all speeds and only when I hit bumps, large or small it doesn't matter.
Also while driving on the highway at high speeds the stearing wheels shimmy's back and forth ever so slightly but very noticable.
I know the lower ball joints are bad but they aren't causing the noise. I will replace them when I replace whatever is causing the noise.
I have never replaced my front struts or my rear shocks.
Jul 31, 2007 at 12:34 PM
I have seen the sway bar links cause this noise and they are easily to replace FYI.
Apr 28, 2025 at 12:17 PM
