Had a common hose leak I thought , the one on the side as you look down upon the P/S pump from the drivers side. So I replaced it and found the leak was still there just below the lower hose end connection point; From a metal line under the motor mount going to the sector. Can't grt my hand in there nor the spanual, very tight indeed.
How does one get to the thing ? Its under a piece of steel & access from down under is blocked too from steel cross members and plating
Any Ideas Please ?
Thanks
James
Any Ideas Please ?
Thanks
James
Aug 2, 2007 at 10:28 PM
