1997 Ford Thunderbird running rich
1997 FORD THUNDERBIRD
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARKTYLR
rough running at all speeds . after resetting computer, car will run fine for 15-25 miles then returns to rough running. replaced one fuel injector and cleaned all others 10000 miles ago
Oct 23, 2009 at 11:33 AM
Running rich:
Could be a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Oct 23, 2009 at 11:41 AM
MARKTYLR
where is it located
Oct 23, 2009 at 1:23 PM
I strongly recommend you bring her in this one can be a nightmare to fix
Oct 23, 2009 at 5:16 PM
